alright cub guys i think i am missing something here. my auger seems to move about an inch back and forth. i have a couple pics may someone can tell me what is wrong here thanks!!
The bearings have locking collars to hold it in place. Align the drive chain and tighten the set screws.
I pulled out the screws and put them back in as tight as i could and the auger still slids. Now with that being said each bearing has two holes BUT each one is missing a screw like the threads are bad in 1 hole on each.
Check and see if the shaft is worn. You may also need to replace the bearings. Maybe you can put some spacers between the impeller and the bearings to keep it centered?
I was thinking the same thing just to get by for now.
I forgot to add that it has twist lock collars, you have to slide it over the cam shaped end on the bearing and twist and tighten it, your bearing keepers may also be allowing the bearing to move side to side a little. The one hole in the collar is blind.
Ok that makes some sense about why the holes look stripped. Question about the twist of the bearing. i can turn the collar on both does that mean i need to keep turning them til they stop and then lock down that set screw?
Well, if you loosen it and pull it away from the bearing you can see better how it works, it shouldn't stop, but will start to spin the bearing( if you look at the outside you will see it start spinning when its locking in) then tighten the screw. At this point it should not move in and out of the bearings, if it does, The shaft is worn like sam said, or maybe the threads in the collar are messed up and the set screw isnt going in far enough to tighten against the shaft.
