Is there a way to put down pressure on the front blade on a 1450? right now it floats and sometimes it would be nice to be able to hold it down. I've had it roll over stuff that I'm pushing.
CC 1450, 44A deck, #2 tiller, 42" plow/blade CC 124 CC 1220 #2 Cart |
Yes, There is a float pin you can install to put down pressure on the blade.
Just be sure to remove it when you install a mower deck or other attachment that needs to float. |
Thanks, Diz Jr. What size of pin and where does it go? Pics or diagram would be nice if someone has them. We have a couple lathes so I can make a pin if I know the dimensions. Thanks, cjet69
Hopefully someone can get you some pictures.
My computer with all the pictures went down this afternoon. Using the daughters lap top at the moment. |
Found a diagram on cubcadet.com parts lookup. Looks like #9 is what I need. Do the rest of you use the lockout or float when using your blade? Is there a downside when using the lockout? like breaking something.
There for sale on Ebay.
http://www.ebay.com/itm/281035097746...84.m1438.l2649
Chug a lug a luggin’ 5 miles an hour On my International Harvester |
Duke's right on the float lockout. Gotta be careful otherwise, that steering wheel hurts.
![]() Same thing on the spring trip of the blade. Some guys wanna ram piles of snow and lockout the spring trip feature. I've told them that ice and frozen rocks don't move too far. They learned the hard way.
Josh Diesel Cub Cadets........... |
On my 1650 I have a dozer blade, I used it yesterday for the first time but was kind of disappointed at the lack of down force. So I pulled the inspection plate and worked the blade up and down, I might have found my problem but I'm not sure. On the parts diagram #3 is one of the link arms.... There appears to be a bushing with a bolt where the pivot rod goes through, is the arm supposed to spin freely on the bushing or if not could I tack weld it to secure it and keep it from moving. The dozer blade is all that will ever be hooked up to the lift so no need for it to float or give. I realize some will say rebuild it with new parts but if welding it works that's what I would prefer to do.
