When I picked up the 1210, it blew smoke on start up, and picking up revs from an idle. Then didn't seem bad. I had hoped it was plugged vent, or maybe carbon build up on rings that would clear.
The vent was plugged, big time, with RTV. And assembled wrong with pieces missing. Thought I was in luck. Now it burns oil much worse, and blows from the vent as well. goes through as much oil as gas. So IMO, I'm looking at teardown, new piston and rings, probably bore OS. What bugs me is this thing fires up fast, runs smooth, and seems to have tons of power. Sure doesn't seem like a compression loss. Have I missed something??
Roger,,109,1450,1210 ![]() Some Days all You Can Do Is Hang On!!! |
Possible Valve Guides....???
I didn't mention, if you take oil dipstick out, it blows/throws little droplets of oil out the fill pipe.
Do a leak down test or at least hook up some compressed air to the spark plug hole. If it blows out the dip stick tube or crank case vent it's rings time. You will need to get the piston at TDC and come up with a way to keep the crank from turning when you do this. If it blows out the intake or exhaust then you have a valve issue.
Darn. I knew I was overlooking something!!!
I knew that!!!! have done it before, usually testing for burnt valve.!!!! Thanks!!!!
China Freight has this little handy device that may help.
http://www.harborfreight.com/cylinde...ter-94190.html
I use something like this
http://www.summitracing.com/parts/an...7/media/images I screw the adapter into the spark plug hole and then just connect my shop air to the quick disconnect. The tester Oak listed would work better.
