Had a blast. Used a 10 inch plow behind my 124 with worn 8.5 ags, a set of IH weights, and 5.5 gallons of windshield washer fluid in each tire. Only issue is I could've used a little more weight. It was all I could do to keep the land side tire from slipping but then again as far as I know this had never been plowed so it was tough.
Tried second gear but had trouble with the clutch slipping so I did almost all of it in first. I think the tractor worked me almost as hard as I worked it! Now I see why people like hydraulic lifts. I may have plowed a bit much but this is the first time I've ever really tried gardening and I figured too much is better then not enough. Plus it was fun ![]() After a few runs I mashed down the pedal, heard a snap, and the next time I went to stop I had no clutch only brake a quick look over found it was just a broken return spring that had allowed the clutch release arm linkage to slip out. Thankful it was an easy fix.![]() This was the end result. Need to disk it next. ![]() The 10'' brinly plow worked good after I got everything adjusted except the coulter was all but useless. seemed to just flex out of the way rather then cut much. Maybe it's just cause the dirt was hard. I've heard of people cutting notches in them to help with penetration and after watching it on the plow it seems like that would work great. Does anyone have any feedback on doing that? I might try to make up a notched coulter wheel to have in case I need to plow something like this again. |
When i was plowing corn stalks with my 12inch brinly. I took the culter off because it wouldnt let my plow go in the ground deep enough.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
Here is my 12 inch brinly on my cub cadet 100R.
Looks like you were busy!
Nice looking plowed dirt! |
Man you weren't kidding when you said you put that 124 to work. Nice job!
Good job on the plowing. Can't do that here as about 3 inches of snow fell yesterday.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
