Old 11-25-2009, 06:11 PM
Mouse's Avatar
Mouse Mouse is offline
Default Piston
Getting parts off ebay. Had a 12hp block, lost it, while I still had it, I bid on a piston and crank. Won the piston and the crank, also won a 10hp block, can I get the 12hp piston in the 10hp block? What does it cost to get it bored out?
Thanks,
Mouse
1969 125 Cub Cadet
1962 Cub Cadet Orginal
2009 Cub Cadet LTX 1046 VT
1963 Cub Cadet 100
1966 Cub Cadet 122
Old 11-25-2009, 06:54 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
neither piston, nor crank will swap. Sorry bud. Boring shouldn't cost much, but you'll want to get the new piston first.
Fly Fishing is not a sport...It's a way of life.
Old 11-25-2009, 07:02 PM
Mouse's Avatar
I want to bore out the 10hp to = a 12hp, and use the 12hp piston.
Mouse
1969 125 Cub Cadet
1963 Cub Cadet 100
1966 Cub Cadet 122
Old 11-25-2009, 07:35 PM
Can't do, A 10hp has a (roughly) 3.250" piston, the 12hp has a (roughly) 3.5" piston. That's 1/4"....unless you sleeve it....but I don't think you could remove that much material without makeing it paper thin....if it even has room to go 1/4".
Second, the strokes different, which means the piston height may be different...but I know the rods are different, so the height may be the same.....doesn't matter. The price of sleeving it is probably higher that buying a new piston.
We'll need someone else opinion here.
Old 11-25-2009, 07:39 PM
Mouse's Avatar
Well I guy can try can't he. If I buy that WH, could I possibly take that engine out and put it in the CC122?
Mouse
1969 125 Cub Cadet
1963 Cub Cadet 100
1966 Cub Cadet 122
Old 11-25-2009, 08:01 PM
It's a kohler 10?, or 12?.....as a matter of fact I'm pretty sure WH used the same engines as cub. Read the k###.
I'd like that WH.....maybe I'll buy it off you so you recoupe your loss.
Old 11-25-2009, 08:04 PM
Merk Merk is offline
This info came from a Kohler Service Manual.
The bore diameter for a 10 horse motor is 3.251.
The bore diameter for a 12 horse motor is 3.375.
The stroke for a 10 horse motor is 2.875.
The stroke for a 12 horse motor is 3.250.
The 10 horse crank will work in a 12 horse power block. I wouldn't do it....not enough stroke. The 12 horse crank will not work in a 10 horse power block. The counterweights from a 12 horse motor will hit the bore in a 10 horse block when the crank rotates.
The last Kohler motor (K321-14 horse block) I had sleeved cost around $85. That was 3 years ago. Odds are it is around a $100 now.
Is the piston new?
