Old 11-27-2009, 08:47 PM
bobsinvt bobsinvt is offline
Question 1572 water pump
My water pump is seeping coolant right where the return pipe meets the pump body. In the parts manual, that return pipe is shown as being available as a separate part. How is it fitted to the pump body? Press fit? Anyone ever replace one? I really don't want to replace the entire pump as I believe that only the return has somehow gone bad. Thanks in advance... Bob
Old 12-07-2009, 05:39 PM
Thumbs up
Guess no one has ever had this problem. Just for reference, I removed the water pump, drilled out the broken return pipe, threaded the pump body, inserted a threaded pipe, reinstalled the water pump. Tractor is good to go for snow plowing. I was told that the original (factory) method of water pump return pipe insertion was a hot pump body, cold return pipe. When at same temp return pipe was sealed to the body.
Tags
1572, water pump
