First time doing electrolysis and everything is going great. I uploaded some pictures.
I wasn't able to find Arm & Hammer Washing Soda. So I went to my local pool store and purchased a 2# container of Sodium Carbonate see picture of it.
Looks like its working good
Let us know how everything works out. |
Here are some pics of my electrolysis set-up. I went all out and built the trelless out of 1" angle in order to support even wheel weights. The small upright is for the positive, or anodes. The black part is some heavy rubber that offers all of the insulation I need. I put five small hooks spaced out for multiple parts. I have since added another anode opposite the first to increase effectiveness. It's all mounted on a 55 gallon plastic drum I cut to about 36".
Looks great, Wayne! I remember checking it out, when I was picking the #2 cart up.
Here's the reason for my building an extra strong parts support frame for my elect. tank. This is my first wheel weight and so far, so good. I used an eye bolt for the main support and a C clamp for the elect. connection. I'm now using a 12v car battery connected to the tank and a charger connected to the battery. It's suppose to give a "cleaner" electrical flow and do a better job. I also added another anode for better conductivity and coverage.
wshytle: How do you regulate the current? I was under the impression that you would want to maintain no higher current than 3A, so as not to make the process too fast and cause pitting. Also, what mixing ratio of soda to water do you use?
Tony Stafford, VA 1650, 682... |
