Does anyone have instructions and/or pictures of how to install a spring assist on a 127? I have one on order. I searched the forums and found some diagrams of it on a 106, but looks a bit different then it would go on the 127. Will I have to modify the back housing sheet metal?
Thanks, Mike |
There were two different spring assists made for Cubs, one is IH and the other was made by Brinly, if I'm not mistaken. Either should fit your tractor, however the Brinly made assist clamps to the lift bar on the 3 point, on the right side in the tunnel and the IH made assist clamps to the implement lift rockshaft, in the left side of the tunnel.
Here's the IH type. http://www.onlycubcadets.net/forum/s...=Spring+assist I can't seem to find any info on installing the Brinley spring. |
They are pretty simple. It either bolts onto the rockshaft w/clamp setup, or there will be two holes on the mower deck lift-arm where a bracket goes (I think that is WF).
The angled bracket bolts to the seat mount panel from undernieth. Take the rear cover off to slide the assm. through, attach the vertical arm from underneath (deck must be off.)
Fly Fishing is not a sport...It's a way of life. |
Sorry Wild Bill, but the underneath shot of 149 shows the two holes I'm talking about. They are on the left mower lift arm. Front implements attach to the rt side where the handle, and 3pt lift bar are located.
I'm trying to figure out how to copy the photo to here....2 years of computer school....what a waste of money!
Thanks Wild Bill, that's what I was talking about. I was thinking of using that set up...seems more stable. But it looks like the mower lift arms are slightly different.
I fabricated my assembly, but the clamp on bracket moves occasionally, it's a pain. So I figured I can drill two holes and make a diff bracket, like the WF .
If the clamp-on bracket moves, I don't think you have it installed correctly. There is really no way for it to move when it's installed the right way.
