Old 07-03-2013, 01:43 PM
djknoedler djknoedler is offline
Default 782 Front Axle Bolt/Washer Specs
Hi Everyone,
I'm finishing a 782 tear down and frame up resto.
What are the correct washers for the front axle/wheel set up? In other words, from outboard to inboard (axle bolt to knuckle) I have bolt/large fender type washer/wheel small washer/axle shaft/knuckle.
Driver's side had the smaller flat washer while the passenger side did not.
Cub Cadet's diagrams for wheels and axles don't show the washers nor axle bolts so I can't get the specs or assembly sequence there.
Thanks!
Pics attached.
Old 07-03-2013, 02:01 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
bolt , big washer and lock washer.
does yours have the plastic caps to go over the washer
Doug
Original , 100 , 125 , 582
Old 07-03-2013, 02:18 PM
It does not have any covers but based on what a previous owner did by mixing and matching fasteners and not re-installing washers where they were designed to go, they could be missing.
Appreciate any pics or explanation.
Also-trying to convert all hardware to stainless-are the big washers just fender style or are they different in some manner?
Thanks.
Old 07-03-2013, 02:29 PM
4SPEED's Avatar
ive only seen them on ccc tractors. there on the front of my 882 the big washer holds the wheel on. its thicker 3/16'' ish
Doug
Old 07-03-2013, 03:29 PM
Thanks Doug-this is a late '81 production so I guess I should have them...odd they aren't on their site. Will have to do some looking around.
Old 07-03-2013, 05:50 PM
4SPEED's Avatar
if you need them i may have a set for you. was going to put um on my 582 , but not now
Doug
