Old 07-04-2013, 01:53 AM
bocephus1991's Avatar
Default What octane of gas do you use?
This may be an old question,so if I apologize in advance. What octane of gas does everyone here use? I'm switching to the high octane alcohol free. Have rebuilt two carbs and my k301 in my 1200 is still hard to start! Its getting enough gas,has good spark has compression and is timed right. I think its the crappy gas. I put new needle and seat,gaskets and the throttle bushing in cleaned the carb inside and out and blew out the needles and all the passages.I 'm gonna try new gas,or some octane booster first and see what happens. The fuel tank is clean as a whistle too,so anyone have some input?? Thanks,Brian
Brian
Old 07-04-2013, 02:52 AM
87. Always. Blended is my only choice. (We have a refinery and an ethanol plant in my county.) I've rebuilt alot of motors, carbs and the like.... sometimes you end up with a "cold natured" motor. I can offer ten different things that can cause a hard start... but I have found sometimes that's just some engines nature. As long as it will start, and it runs fine... you just have to deal with it. Try the higher octane fuel, it may help. Sounds like you've checked everything I would have suggested!
Old 07-04-2013, 06:47 AM
I think you are wasting your money! I use 87 octane E 10.
The main thing with E 10 is to use storage cans that are sealed to keep water out. Don't leave your tractor sit out in the rain.
Old 07-04-2013, 07:19 AM
I run Sonoco 93 no ethanol only because I can't get 87 no ethanol here. I'd prefer 87 if I could get it. Alcohol belongs in booze not gas.
Old 07-04-2013, 07:28 AM
cubs-n-bxrs's Avatar
87 octane laced with Startron. Great stuff.
Old 07-04-2013, 08:09 AM
nikster's Avatar
nikster nikster is offline
Same, same!
87% plus Startron----------------- engine runs happy, happy.
Enzyme to kill ethanol, plus proven to reduce carbon build-up.
Nik
Old 07-04-2013, 09:50 AM
eddycurrent eddycurrent is offline
Just got my ltx1050 using shell 93. Probably extravagant but I do not plan on having another mower as I'm 63 now and want to give the machine every possible advantage.
Old 07-04-2013, 10:39 AM
I run 91/93, whatever the top fuel is at the pumps with Startron and MMO. The cheap plastic cans that don't seal very good, some not at all, are kept in an unconditioned shed on top of a wooden pallet. I have never had any fuel related issues.
