Old 07-18-2013, 09:19 PM
cub149's Avatar
cub149 cub149 is offline
Default 1810 need help fuel pump
I am putting an electric fuel pump on an 1810 and need to know what wire from the igntion I should use. I was thinking the white wire going to the hour meter?
I can't post a picture of the wiring diagram but here is the link to the pdf file. It is on page 110. Thanks for any help.
http://www.onlycubcadets.net/pdf/772-3899.pdf
Chip T.
Drexel NC
Old 07-18-2013, 10:55 PM
That will work and also put a manual shut off after the pump to run the carb out of fuel before you shut it down.
Old 07-19-2013, 12:22 AM
I really don't think that is necessary..... the old mechanical pump pumped fuel till the motor stopped turning. This one will die with the key.
Old 07-19-2013, 12:40 AM
I don't know much about pumps but can they still pass fuel if the float sticks open and on the 82 series the tank is above the carb? I put those cheap little red and black shutoff valves on all my gas machines if the tank is above the carb. Actually, I removed the pump on an 1811 I had and never had a problem with gravity feed.
Old 07-19-2013, 12:49 AM
Sure, they can still pass fuel if the float sticks. But, if everything is in good working order, that won't happen. It's no big deal, and I'm not argueing one way or another. But there is already a shut off on the tank.... I never shut mine off. If I have one that starts to leak, I just fix it. I've seen as many problems with dry-bowl carbs that leak because the seals dry out as I have seen floats stick. It's 6 to 1, half a dozen to the other.
Old 07-19-2013, 09:58 AM
inspectorudy's Avatar
One thing to remember when you switch to an electric pump is when you are doing anything with the key on the pump will be running. If all is well in the carb that will not be an issue. But if as mentioned above the valve is stuck open then you will be flooding the carb and engine. If for some reason you are diagnosing an electrical problem while keeping the key on for a long time you might want to stick a separate switch in the circuit to disarm the fuel pump. In a fuel injected vehicle the electric fuel pump has a return line for the unused fuel and there is no pressure build up on the pump. I do not know what happens on one of our engines if the fuel pump is allowed to run for a long period of time with no pressure relief. Maybe one of our gurus can tell you.
1811 Hydro
