Old 08-15-2013, 09:58 PM
V30crewcab V30crewcab is offline
Default 60" haban belt?
I have a 374 haban 60" deck on a early 1782. the 94" belt it calls for is too long, for some reason. I ordered a 92 to try, but it wont be in til tomorrow. its got 4" pulleys on the mule drive, and a 6" pulley on the deck. any ideas as to why the stock one is too long? the adjustment was all the way out and it was slipping some.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 08-16-2013, 07:03 AM
Go to Tractor Supply with your old belt match it up and get the next 2 smaller size Kevlar belts try them on and use the one that fits best and return the other one. My guess is the PTO, mule drive or the pulley on the deck have been replaced at some point by the PO and they may be the wrong size.
Old 08-16-2013, 07:24 AM
Leadslingingdaddy's Avatar
Something is amiss as I use the 94's from TS...
Is the hanger system correct?
How far forward are the quick attachments forks going into the support hangers? These are the front eyebolt looking things...
Old 08-16-2013, 01:48 PM
they stick out about an inch in the front of the little hanger loops.
there is actually grooves in the front of the bracket from the pulley rubbing it from the belt being too loose.
looking at partstree schematics it almost looks like the hanger brackets are for the newer deck. but the mule drive has the smaller 4" pulleys of the early setup. the later ones show to have 5 1/4 pulleys. the deck is about an inch from the rear tires so it can't really go back any further.
I just went to tractor supply and the next smallest belt they was a 90, and they were out of it. still waiting on the 92 I ordered from the parts store.
72 scout
IH 404 tractor
Old 08-16-2013, 03:18 PM
OK first you have the deck mounted in the wrong holes at the rear. The pin goes in the rear holes. That is going to move the deck forward. Yeah I know the belt is already too long and this is going to make that even worse. Next you have an early Haban and I'm guessing that the pulley on the deck is the small one. You are going to need to measure the diameter of both the center deck pulley and the PTO. One we get it set up as it should be then we can worry about the belt.
Old 08-16-2013, 06:31 PM
dag1450 dag1450 is offline
I know I have seen that belt spec at 94 inches but im pretty sure the correct size is 93 inches. That's what I have bought in the past and I just noticed mine on the 2072 is starting to fray so I will b buying another from "v belts for less" .com. like $18 plus shipping. I went with the Kevlar one last time and it lasted about two or three yrs mowing 3 acres every week. Dave
