Old 12-30-2009, 10:59 PM
dieseldog558's Avatar
dieseldog558 dieseldog558 is offline
Default front pto adjustment
is there any way to adjust the front pto without the guage on a 127?
Old 12-30-2009, 11:03 PM
Trial and error....good luck.
Old 12-30-2009, 11:05 PM
you wouldn't happen to have an extra gauge would you Matt?
Old 12-30-2009, 11:07 PM
Unfortunately not...I've only ever bought 1 rebuild kit. I wonder if someone has a drawing of the gauge...?
Old 12-30-2009, 11:09 PM
yeah that would be nice to see the measurements...be easy made wouldn't it
Old 12-30-2009, 11:38 PM
Some may disagree but this is what I do.
1.) Remove the PTO.
2.) Tighten the jamb nuts on the back side a little bit keeping the tension even between the three screws.
3.) Slide the PTO back into its basket do NOT replace set screws.
4.) Clamp some Vice Grips on the drive shaft.
5.) By hand, physically try to turn the PTO.
6.) Check the engage lever to make sure it will release.
Depending on how easy it slips, repeat steps 1, 2, 3, 5, and 6, until it is difficult to make the PTO slip. As long as the tension between the three screws is pretty even, you should be good to go.
Do not forget to replace the set screws after final adjustment has been made.
Old 05-08-2010, 09:26 PM
Shorty123 Shorty123 is offline
Kind of a related question. My Model 123 has been adjuted to the .015 gap between button and spring plate. The PTO stays engaged full time. Any thoughts on how I can fix this?
Old 05-08-2010, 09:45 PM
MBounds's Avatar
MBounds MBounds is offline
Hi Shorty..Welcome to the OCC... There's help for the front PTO but it would help a lot to see the the PTO when 1) engaged and 2)when you have pulled the handle and it's supposed to be disengaged. 2 photo's would tell those of us familiar with them a lot. My crystal ball quit working and I can't see what 's wrong from way down here in Texas...(:-}>...
Myron B
East Texas
Most of of the fleet:
Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with.
Old 05-09-2010, 12:14 AM
LOL @ the crystal ball! I'll tune up the reception on that with some pictures tomorrow morning. Thanks!
