Last night an 1882 followed me home, She's not much of a looker, but has a lot of parts i was after. I bought it for parts for my project quietline (dropping in a different engine, so the cv driveshaft is a big deal) I was thinking about dome of the other parts on this cub and found myself wondering about parts being interchangable (well at least bolt up) and which are the better parts to use. I am going to use the cv joint shaft on the project tractor, but I dont know about differences between the hydrostats (pros/cons) and the rearends (cast vs. aluminum, pros/cons)
Input is appreciated. |
Also, I havn't had much of a chance to compare yet, but any opinions on front axle durability between a late model quietline and an 1882? If I remember correctly, My 1650 is a '79, so it should also have the 1" spindles?
How about some pics of the 1882. I don't think a lot of the 1882 is going to be useable in the QL. Just my 2 cents but I would save the Super before the QL.
I will have to wait till I get back to the shop to take some pics. The QL is a project that I had decided to do, just because it will be a challenge and therefore fun. I like the older metal. I had one bad pic of the 1882 to go on before I went out to look at it, and was a little torn as to what I was going to do. The QL is a base for a liquid cooled diesel conversion (not easy, I know) in the end it will be more of a super QL (power steering, cat 0 3pt, aux hydraulics, whatever else that may be added to it)
While the metal is fixable on the 1882, the plastic is not. Well, it may be, but that is not the kind of work I have any desire to get into. I already have the additional metal parts to stretch the QL, and I don't want to track down a complete replacement nose for the 1882. I guess I should have started this thread a little differently. |
Given the choices below, which are the better options (with any justification if possible)
su15 hydro or whatever is in the 1882? (from a previous conversation they may be the same, just with a different input shaft) the cast iron rear end from a QL, or the cast aluminum one from the 1882? front axle from the QL or from the super? (I do plan on putting the super power steering on, maybe not right away, it will go on the super QL) |
