Old 01-20-2010, 09:45 AM
ChrisA ChrisA is offline
Default Hydraulics
I am in the process of rebuilding the steering on my 882D. The spool valve is mounted on the steering column, so I had to take the valve off to get the column out. I disconnected the hydraulic lines from the spool valve. When I have everything back together there will be air bubbles in the system. Do I need to bleed the system like I would if I disconnected a brake line on an auto, or will the air clear itself out? If I do need to bleed it, what is the correct procedure? Thanks in advance.
Old 01-20-2010, 12:14 PM
Nope, just run the lift up and down a few times and the
air will work its way out.
