I would like to remove the steering wheel from my Cub Cadet 105 so that I can repaint the tractor. Is there a good way to remove a steering wheel without destroying it? The curved plastic base will not allow a wheel puller to be used.
Thank you for your suggestions. |
PB Blaster and patents for starters.
Here is what I used on my original, granted the spokes aren't coated.
Make sure you have a nut on the threads Zippy or you will split the shaft.BTDT
Good point Lew. But this time everything worked as planned.
Zippy he is refering to a 105 steering wheel removal. Using that set up will mash the tapered plastic botttom of the steering wheel. BTDT I have had better luck with a steering wheel puller connected to a clam shell puller on the bottom of the plastic. Draw it up up pretty snug and give the end of the threaded rod a good smack with a hammer. Should dislodge it.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
