Well, since I had Turkeyday off with a few hours to spare, I decided to work on the 1450. Today's goal? Remove the motor. Removing the motor was a learning experience as I'd never removed a Cub motor before but it all ended well. I should hopefully (crosses fingers) have my new engine cradle and mounts in this weekend along with my new hydro fan. Anywho, on to today. I removed the gas tank, hood, and grill. Easy enough. I then moved on to the motor. I attempted (and successfully completed
) removing the ISO bolts only to realize that the motor wouldn't come out. So, I searched around. I found that by cranking one end of the front axle up at a time, I could remove the actual bolts that hold the motor to the mounts. After a bit of finagling, I got all 4 bolts out violla; had the motor free. I grunted and lifted it out to freedom! I snapped a few pics and called it a day to get ready for Turkey Day feast. So here's the pics I took, looks like the ol girl needed the new mounts that are on the way I'll be sure to post back with more pics when I get her completed. ![]() ![]() ![]() ![]()
-Ryan
If you lifted that k-321 out of its mount without some sort of a hoist, you are pretty good. That is why a lifting eye came on those engines from the factory.
Having said that, I did that job a year ago on my 1250 Nightmare. I had a local welding and machine shop do the recommended engine cradle modification, and after rebuilding the steering sector and tightening the front axle yoke, I now have a machine that doesn't shake too badly and steers well. This is a great project! It took me awhile to get everything set correctly once back together, but it was all worth it in the end. I wish you great success in this process. |
Sweet!
![]() And I debated doing some steering work but with winter fast approaching and space soon to be a premium, I decided against it. It's not too bad as is, but will need some work in the future. ![]() Thanks!
-Ryan
Lookin good Ryan!!
Nice progress on the 1450!
