Old 01-18-2014, 05:29 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Default Heavy duty spindles
i was wanting to see if anyone has done the heavy duty spindle swap to the front wheels. i saw one member with it done but i cant seem to find out who it was. i think it would be a good modification to my 1772 with the KW loader. so far the OEM ones have held up, but with a few hundred lbs. in the bucket who knows for how long. i see there is a kit from Xtream that looks good. if anyone has done this id love to see how its done and how it holds up. thanks!!
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-18-2014, 05:44 PM
TIMCRUTCHER TIMCRUTCHER is offline
I did it. Check my post. I used 1500 lb. 1 1/2 square spindles and machined a block to give correct angle. PM me for pics.
Old 01-18-2014, 05:48 PM
What post would that be?
Old 01-18-2014, 05:56 PM
Spindle laid out to weld.
Old 01-18-2014, 05:58 PM
Spindle laid out to weld.Attachment 46297
Put up a post about the spindle upgrade, looks beefy to me.
Old 01-18-2014, 05:59 PM
Finished
Old 01-18-2014, 06:07 PM
Your not getting off that easy, we want details and more pics. Don't try holding out on us now
Do a new thread on your upgrade
Old 01-19-2014, 09:01 PM
CTRUEX CTRUEX is offline
I don't use my Cub, I just work on it and look at it, so far it's holding up very well.
I like that! Nice job on your spindles/front wheels, very cool!
What about welding in 1/2" thick gussets where the factory spindles are bent? I've seen this done before, and would be almost as strong as Tim's, just not as cool. Also, front hubs off of a Lo Boy, along with 5 lug 8" golf cart rims, would be stronger than what MTD/IH put there.
Old 01-20-2014, 01:28 AM
GREAT JOB on the spindles!
Really wish you had taken more pics!......
We'll let you off the hook this time! But next time MORE PICTURES!
Just a thought:
Why not machine of the bottom of the axle itself and put a thrust bearing between the spindly and the axle like a big tractor. It would make it easier to steer.
Old 01-20-2014, 09:35 AM
ken6x6's Avatar
interesting point CTRUEX. i just looked at a few pix of the lowboys front hubs. has the same bend as the cubs. your saying i could take lowboy hubs and install them on my axle and they would fit? if that's the case im in.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
