I posted an update on my 1450 project here: http://www.onlycubcadets.net/forum/s...t=29556&page=4
Any help with this tractor is appreciated. This is my first hydro and I want to put it back together right. Here's a couple of questions: 1. Is sector shaft side-to-side play acceptable? 2. Can I remove the sector shaft and put it back in without disassembling the pump? Will the swash plate fall if I remove it? 3. Is play between the cam plate and trunion plate acceptable? Thanks in advance, Bob |
I haven't had this shaft out of the pump. What picture did you see that in? |
I've said this on here a lot, but I'm going to say it again. Hydro's are a very high precision made pump. Taking one apart, is sometimes necessary, but IMHO, not for the novice. Almost all general repairs can be made with out disassembly. If disassembly is necessary, take your time, and be as clean as if you were doing surgery. Dirt is the ultimate enemy in a high pressure piston pump.
Here is an article in our tech section. http://www.onlycubcadets.net/forum/s...ad.php?t=25192 |
Go to the tech section on this site, where I referred you to earlier, download the chassis manual for the 1450. It covers disassembly of the hydro. |
