I was using the Wix Filter Lookup to find the correct hydro filter for my 682. It shows 51084 but I'm not sure that is right because it has an anti drain back valve. Can anyone confirm if this is the correct filter?
http://www.wixfilters.com/Lookup/App...aspx?Section=4 |
This may help........... Hydro Oil Filters
Wix 51410 is the correct number. The 51084 is an engine oil filter. My grandfather put one on the 1811, who knows how long it was on there! No ill effects were caused. I replaced it after the driveshaft rubbed a hole in it
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
The 51410 will work on all Cubs but was designed for the HG hydro's in the cyclops line, 2k &3k machines. The 51084 has the anti-drainback valve and works well on the older machines with the Sunstrand pumps but not on the newer machines with the HG pumps. The 51084 will keep the pump full of oil so on the next start up it doesn't start dry.
Thanks to Todd Markle.
I assume the new MTD filters have no anti-drainback valve. Do they have one for the older IH tractors or does it really not matter?
The Wix 51084 has a nut on the end like the original IH filters. |
