Old 03-03-2014, 10:11 AM
dbuck dbuck is offline
Smile Snow plow weight?
Needing some ideas/suggestions on adding weight to my snow plow/front end with the plow attached. I have tri-ribs on the front and while pushing snow with/with out ice underneath, while trying to correct/turn the steering the front end keeps going straight. Thank you for your time.
Old 03-03-2014, 10:19 AM
PaulS's Avatar
PaulS PaulS is offline
For just that reason I love my super with individual wheel brakes. Just a touch when turning starts the turn and keeps my rig on track. Only problem I have is it has been so cold here most of the winter my boots are almost too big to hit the inside (left) brake without also hitting the other one.
Old 03-03-2014, 10:49 AM
mmzullo mmzullo is offline
Try loading the front tires. It will probably be not enough but might help. Try to use a 25 lbs lifting plate on the sub frame up front. Might fit. I only have that problem with the 1811 when the snow is wet.
Old 03-03-2014, 11:11 AM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
I have that problem from time to time. It tends to only happen in heavy snow. I just corrected my problem by plowing in straight lines only besides, whenever I turn while plowing I end up running over my snow piles.
I lost track of what I own a long time ago!
Old 03-03-2014, 03:48 PM
charlie105's Avatar
charlie105 charlie105 is offline
Default plow weight
Went from old/nearly bald front turfs to ags on the front, what a difference.
Old 03-03-2014, 04:24 PM
CNeubauer CNeubauer is offline
I heard of a guy who let enough air out of the front tires to wrap them with a length of #40 roller chain around them and then pumped the tires back up tight against the chain to hold it in place.
Old 03-04-2014, 12:02 AM
Berwil's Avatar
Berwil Berwil is offline
When plowing with my O, I pull back on the lift handle just enough to transfer the plow weight to the front tires and it turns every time. A hydro lift wouldn't have the same "feel", but it would still work. For the number of times I am pushing while turning, this is good enough for me.
Bill
Old 03-04-2014, 08:23 AM
Smile
Thank you everyone for your replies, some great ideas/suggestions. PaulS, I wish my 149 had turning brakes. Mmzullo, I do have some free weights, I will check and see how much room I have on the sub-frame. Charlie 105, the turfs would build up with snow and would act like racing slicks, that is the reason I when with tri-ribs.
Old 03-04-2014, 05:49 PM
charlie105's Avatar
Default tires
Yeah , the turfs were miserable, but Ags on the front made all the difference for me.
Old 03-04-2014, 08:55 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
This is my 149 it doesn't turn great but if I had a set of tri ribs it would work great. I was going to get a set of V61 tires for it. The front weights are 30# each the rears are 55# each the rears are filled with windshield washer fluid. And i put tire chains on it the snow.
