Old 03-03-2014, 01:54 PM
Default Tandem disk on a sleeve hitch
Just got me two disks, and I arranged and bolted them together to make a tandem. Just did it to see how heavy they would be. Plan to make the two frames into one, and put it on 3pt. (The cat 0 Brinly disks are too hard to find). Anyone running a tandem on a sleeve hitch? I wanted it have both a cat 0 hitch and the Brinly on it, but, man..... breaks my arm lifting the silly thing! Yes, I have spring assist, but I think it may just be too much. Flexing the adapter an awful lot. So.... anyone else have tandems on sleeve hitch?
Old 03-03-2014, 03:24 PM
I think I would rather pull a single gang, with extra weight in the weight box, for a garden.
The dual gang with weight in both boxes would be great for a field, where you do not need to lift the gangs, just keep on going!!
Either way, the discs need weight to be effective, in most soils, single or dual gangs.
If I were going to gang them for a 3 point, I think I could consider wheels in between the gangs, 3 pt operated, of course.
Then the wheels would be your weight, and the lift would be located where it would do the most good.
JMHO
Old 03-03-2014, 09:51 PM
Nice find, Jonathan!
Old 03-03-2014, 09:55 PM
JMHO
I think you are probably right. It is going to be a 3pt disk, but I know I've seen pics of tandems on sleeve hitch, but they may not have been these. They are both pretty heavy! No biggie. I was planning on having depth wheels on it when its done. Like I said, this isn't the way I'm going to run it...... I just wanted to see if I could lift it!
Thanks Allen!
Old 03-04-2014, 01:20 AM
Extra bowl of Wheaties in the morning.
Did you get my email Saturday?
Nice tandem by the way.
Old 03-04-2014, 05:58 AM
Nice tandem setup Jonathan!
Old 03-08-2014, 02:34 AM
clint clint is offline
Default like this
Like this???
Tractor >< if that makes anymore sense >< is the harrow
edit (can't get picture to quote)I thought you had them facing opposite than they are. you can still get them much closer together, and to tractor which should reduce overall lifting weight. Yes I know how they work in tandem like your trying to setup the set behind tractor cuts the set away from tractor smooths/bust up clods is the way they are supposed to work.
1440
1282
1604 cast rear/transmission (582)
149
1450 (2)
JD317 54" blade
JD318
Ford 3600
Old 03-09-2014, 03:10 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
If I ever use a double ganger it will be on a hydro tractor. As for the two different discs it would apperar that the rear disc is a newer Brinly.
I lost track of what I own a long time ago!
Old 03-09-2014, 07:55 PM
jchristensen jchristensen is offline
I have mine set up as a tandem on a sleeve hitch. It is HEAVY and I put weight on it too, but that is why I added hydraulic lift to the tractor. One tip for you though, where the connection is for the front and rear, you should have a section of square tubing with a hole through the middle for the bolt. That will keep the rear more rigid and not flex so much.
I have a dream of one day converting mine to a wheel carry style, then I can really weight it down and do some damage.
Old 03-09-2014, 10:36 PM
Oh, I'm not done with it. I just bolted it together to see if I would even be able to pick it up. Plan is, to make a new frame. If all works out, I have a Cat 0 spoken for, so I'll just make it look like the one Oak posted. It won't be used to break ground, I have a plow (and other tools) for that. Just want to use it for after the plow, and before the tiller.
