Old 04-15-2014, 09:33 PM
thadscub's Avatar
thadscub thadscub is offline
Default Cub Cadet 122 throttle cable
Hi guys, I need to know if anyone just sell the throttle cable, with out the ends, just the cable. And, where to purchase a gasket for the sediment bowl
Old 04-15-2014, 10:29 PM
macman81's Avatar
macman81 macman81 is offline
I have the bowl gasket at work. I Had to buy a ten pack to get ONE, so I have 9 extra ones. Send me a couple bucks and I'll mail one to you!
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 04-15-2014, 10:42 PM
thadscub's Avatar
are they the rubber or cork gaskets
thanks thad
Old 04-15-2014, 11:10 PM
I've never seen just a cable for sale. I have, however, bought a throttle lever/cable and removed the cable and installed it on an old handle.
Old 04-15-2014, 11:20 PM
thadscub's Avatar
how long is the cable supose to be
Old 04-15-2014, 11:52 PM
Berwil's Avatar
Berwil Berwil is offline
I don't know the length, but if you have the handle you can go to the hardware store/small engine shop and buy a long generic throttle cable (measure a rough estimate first) then switch it over to your handle like j-mech said. If you made it that far, trimming the length is easy once installed.
I think you can use gasket paper if you have some lying around. Trace the outside of the bowl and a socket that matches the id of the bowl. Instant bowl gasket.
Bill
