Old 05-19-2014, 03:19 PM
dakota1205 dakota1205 is offline
Default 2072 ignition coil
Have an 2072 with a Kohler repower CH730-0097 engine in it. looks to be a 2004 year model. Had to replace the rear seal in it, so while out (and had to remove ignition coils anyway) I thought I would ohm the coils (reason being, after mowing for a while and shut it off, it backfires and wants to stay running, then finally shuts off) one coil reads 8.97k ohms to ground and the other reads nothing. I believe the one reading nothing, might be bad. Is there a correct way to ohm them or do you have to have connected back up and check it at the spark plug with a tester.
Thanks for any input
Randy
Old 05-19-2014, 06:41 PM
Page 42 in the Kohler CH manual gives you the readings to check for. I think you have figured out though.
Old 05-19-2014, 06:49 PM
t would seem that if one of the coils is bad, it would run real rough.
Old 05-19-2014, 11:49 PM
well put engine back in and checked each plug and it had spark. so i guess all is well, runs good, except it still backfires when you back off of the throttle. Any one know why it still does this?
Old 05-19-2014, 11:55 PM
Usually an exhaust backfire on deceleration is because of an over-rich fuel mixture.
Other possibilities are:
-leak in the exhaust that lets air in
-vacuum leak
-exhaust valve not seating
-timing off (not likely on a magneto ignition, but possible)
More than likely, too rich on the carb.
Old 05-20-2014, 08:14 AM
In addition...your engine maybe running hotter than normal too.
