Old 05-20-2014, 12:03 PM
TRBOJET TRBOJET is offline
Default Cub Cadet 1641 Electrical Issue
I am rebuilding a CC 1641. It's all back together. I was having issues with the electrical blade clutch engaging. I figured it to be a ground issue. In the process while jumping a wire from the rear of the ignition switch, I noticed that every time I started the tractor I was frying the jumper wire. Everything is normal after the starter is disengaged. Why am I frying the wire just when the starter is engaged? I have a good ground to the starter. Bad relay? Starter? Any help would be appreciated. Thanks.
Old 05-20-2014, 12:22 PM
Well....... why are you jumping a wire? What wire are you jumping? I would say you are frying it, because it's not supposed to be there. Don't do that anymore.
Old 05-20-2014, 12:34 PM
I'm jumping the ground wire (Green) from the back of the ignition switch to ground.
Old 05-20-2014, 12:43 PM
What is that...????
Old 05-20-2014, 12:49 PM
I guess you would call it the PTO
Old 05-20-2014, 12:53 PM
unless I ground that one tab (that the schematic shows as ground) the lights and the PTO do not work. very frustrating.
