Old 05-29-2014, 03:26 PM
Default Trailer brakes
I have a 3 axle flat bed and I can't seem to get the brakes to work. All new wiring and magnets, the shoes are still like new. Im getting 13.5v at the brakes with a good ground and even turned up to 10 on the controller it barely does anything. Any ideas? Ps the truck is a 2014 f350 and we have 3 trailers and this is the only one we have problems with
Old 05-29-2014, 04:21 PM
Did you adjust the brakes?
Old 05-29-2014, 04:27 PM
Yes sir, everything is adjusted up.
Old 05-29-2014, 04:34 PM
Any chance you got the right and left sides swapped? They are designed to pull with the wheel rotation to actuate the shoes. Only other thing I can think of is the magnets are to far away from the surface of the brake drum.
Old 05-29-2014, 04:43 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
How rusty was the magnet surface on the drums?
You might get your 13.5v
But that means nothing if the amp draw is not right.
You can check the resistance and the math will tell you the amps.
http://www.etrailer.com/faq-testing-...-function.aspx
Old 05-29-2014, 04:51 PM
cub123's Avatar
cub123 cub123 is offline
What Sam said with the shoes^ Also I'm not sure how the fords are, but my 14' Ram has different settings in the menu like light, medium, and heavy trailer as well as being able to set it from 1 to 10.
Old 05-29-2014, 05:15 PM
everything is on the correct side and theres no rust on the drums. i will test for amp draw tomorrow
