Old 06-08-2014, 03:38 PM
jimbob200521's Avatar
Default Off to pick up another
Well gentleman, the bug has bit again. And this time, I think I'll pull a J-Mech and make y'all guess what it is Here's a couple hints: it's made between 1993 - 1997, it's got a 54" deck, and hydraulic lift. Any thoughts? I'll be sure to post pics when I get her home!
-Ryan
Old 06-08-2014, 04:01 PM
ccpullin ccpullin is offline
How about a 2084 with a 54" mower & 54" blade
Old 06-08-2014, 04:23 PM
Sounds like a Cyclops!
Old 06-08-2014, 04:35 PM
I agree.
Old 06-08-2014, 04:45 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
My guess is an 1864
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 06-08-2014, 04:57 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Originally Posted by RR1862CC View Post
My guess is an 1864
If he is lucky that's what it is!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-08-2014, 07:54 PM
1864 since j-mech has one.
Originally Posted by Rescue11 View Post
1864... yes no?
My guess is an 1864
Well you guys sorta win as you were the closest
About time you bought one of the best.
Well Sam, I hope you consider this a good machine, although I doubt it stands up to one of your Supers I've seen pics of
BTW Sam, I'm ready for the critiquing/suggestions from the Cyclops guru for what I need to check into! lol
So guys, as much as I would have loved it to be an 1864, I'll have to settle for this guy. She's in good running shape, although she will need a bit of TLC before she's in tip top running condition. The engine is in great shape, no smoke, sputtering, doesn't burn oil, no weird noises, etc. The trans doesn't make any weird noises but I still plan on changing fluid/filter asap. Also, it will need the linkages adjusted because as it sits, things don't allow it to get to top speed right now. Other than that, PTO works fine, wiring seems decent, I don't see any fuel or hydro leaks so it's got good potential. Anywho, on to the pros/cons as well as a few pics. Hope ya'll approve!
Pros:
Machine only has 459 hours on it
Solid engine. No smoke and fires right up
Plastic panels are all in pretty good condition, save one crack in the hood
Deck spindals are all in good shape, spins easily and freely
Cons:
I'll have to re-run the fuel line as some stupid a$$ PO ran it outside the fenders. WHY?!?! (you can see it run by the brake pedal)
Hydro linkages need adjusted as she doesn't get up to top speed in forward or reverse
Couple good scratches on both sides of the fenders
Steering is a bit loose
Anyway, on to the pics!
-Ryan
Old 06-08-2014, 08:52 PM
I thought for sure you went after this Super right down the road from you
http://rockford.craigslist.org/grd/4508520080.html
Old 06-08-2014, 09:24 PM
I thought about it, but too rich for my blood
-Ryan
Old 06-08-2014, 09:32 PM
Ryan, I have the engine SM on PDF. I can send it to you when I get to a pc. PM me your e-mail.
