My 127 runs pretty well and has done so for so for nearly 40 years. However, if I don't let it idle for 30 seconds or so after cutting it will backfire thru the exhaust when I turn the key off. What is up with that.
Same problem with mine. I think that is normal.
I don't think that would be normal, particularly as it did not do that for the 1st 38 years or so.
Several things to check: carb --perhaps your air or fuel intake settings need adjustment or maybe the carb needs rebuilt, spark plug, timing, or are you shutting it off and then while the engine is stopping are you pulling the throttle down to minimum?
Sounds rich to me, my mower (1015) does that. I'm not changing it though because I like how it starts. I may also be completely wrong.
Philip 1450, 1015, and a pile of parts. |
I always let mine idle,it helps cool the motor. Also I run 89 which will also help solve your issue, not to say there isn't another cause but if it runs good otherwise I wouldn't mess with it
