Old 06-18-2014, 11:43 AM
imnotacollector imnotacollector is offline
Default 782 help please.
So I put the deck on to try mowing for the first time since I bought it. Before I began I checked the oil and it was at the top of the hash marks. After twenty minutes or so of mowing. I was going straight up a small hill, towards the top I heard a puff and then it had a lot of smoke. When I opened the hood I see that I have oil dripping from the breather. When I check the oil now it is a little high. Could the fuel pump be leaking into the crank case? It is a series 2 kt17. Thanks for any help.
Old 06-18-2014, 12:45 PM
Nitro's Avatar
Nitro Nitro is offline
Were you on the hill when you checked the oil, or was the tractor level?
Philip
1450, 1015, and a pile of parts.
Old 06-18-2014, 12:48 PM
jimbob200521's Avatar
Smell the oil and report back. I would be a slice of pizza your fuel pump took a dump on you.
-Ryan
Old 06-18-2014, 12:52 PM
I will do that as soon as possible, but I have to get ready to go work right now. It will probably be tomorrow morning before I have an update. I do thank everyone for the help though.
Old 06-18-2014, 12:49 PM
It was back on level ground.
I say fuel pump.
But how do you "hear a puff"?
Old 06-18-2014, 01:03 PM
BCDSFCRET BCDSFCRET is offline
Default Bcdsfcret
If you have oil dripping from air breather. Breather valve in the valve tappet is shot. remove and replace. Oil will quit coming up breather tube.
Brian
Oh by the way I have 15 of them and I never had a fuel pump leak gas into the crankcase.
Old 06-18-2014, 08:19 PM
Originally Posted by BCDSFCRET View Post
Oh by the way I have 15 of them.
I really want to see pics. You have (15) 82 series? Cool
Old 06-18-2014, 10:55 PM
Brian
I think you may be referring to the reed valve, or "umbrella valve" as the parts book calls it. And no, that is not necessarily bad. If it does have gas in the oil, it will puke through a good valve. I understand that you own a lot of these tractors, but just because none of yours went bad, doesn't mean that lots of them don't. It just means your lucky. On the forum, there have been close to 15 fuel pumps fail this year alone, that filled the crankcase.
Old 06-18-2014, 03:50 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I say fuel pump.
puff [puhf] Show IPA
noun
1.
a short, quick blast, as of wind or breath.
2.
an abrupt emission of air, smoke, vapor, etc.
3.
an act of inhaling and exhaling, as on a cigarette or pipe; whiff.
4.
the sound of an abrupt emission of air, vapor, etc.
5.
a small quantity of vapor, smoke, etc., emitted at one blast.
#4 I say fuel pump too.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
