Old 06-24-2014, 12:09 PM
rdehli rdehli is offline
Default 2072 drive line question
did all of the supers have an in-line clutch on the driveshaft by the hydro fan? what is the purpose of it?
Old 06-24-2014, 12:11 PM
Shaner Shaner is offline
no not all supers did. the reason for that clutch is to disconnect the drive shaft from the rear hydraulic pump for easier cold weather starting. easier to let the engine start itself without turning the cold rear end as well.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 06-24-2014, 12:35 PM
In addition, that "disconnect clutch" was also offered on regular garden tractors also.
Old 06-24-2014, 01:43 PM
squatch squatch is offline
Mine doesn't and last winter I sure wish it did. Single digits temps and old fuel. couldn't get it to spin fast enough to start till it warmed up some. I've since installed heat in my garage because of it.
Old 06-24-2014, 02:13 PM
nice heater, what kind is it and where did you get it...
Old 06-24-2014, 02:23 PM
here is a pic of my drive shaft the p/o said he replaced the shaft twice then installed an in-line bearing, I would much rather go back to factory stock. Does anyone have the specs on the shaft dia...length and the holes for my 2072 with the in line clutch?
Old 06-25-2014, 12:22 PM
2 of these. Made in USA!
http://www.amazon.com/dp/B0000AXEZV/...=dradisplay-20
2 of these.
http://www.amazon.com/Honeywell-Manu...ef=pd_sim_hi_4
Both wired into the 100 amp sub panel in my garage. 220volt.
Back to the thread.
