Expert advice needed!
A friend of mine needs a bolt welded onto his tire carrier. Naturally it's mounted on the tail gate & swings out to open the cargo area. I heard that by connecting the negative ground to the vehicle & welding on the vehicle (tire rack) one can damage the computer on the vehicle? I'm reluctant to do this simple task until a get a positive yes or no. Can the computer of the vehicle be damaged? NIK, Thanks.
It dont cut grass, but its yellow. |
I work in a collision shop so i weld on cars daily and thats mostly a bunch of bs. The power will go straight from the torch to the ground so unless you put the ground on the other end of the car you'll be fine.
I've heard of it happening. Just disconnect the battery to the vehicle first to avoid any worry.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169. Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3. |
Exactly, why take chances when you can disconnect the battery in a few minutes.
I've urban legend I've heard plenty of times is that even with the battery disconnected the computer can be damaged. I never actually seen it happen and call BS to the entire notion. The power is going to take the shortest path to ground which is not going to be through the computer. Disconnect the battery and weld away.
Thanks to EVERYONE!
![]() ![]() Nik
