While rebuilding my mule drive, I have seem to lost the spacer that goes with the idler adjuster on the mule drive for my 149. The PN: 545687-R1 is NLA. Could someone give the depth so I can machine one? Or maybe someone has an extra I can buy? Thank you for your time.
Don B, USAF 1962-1968, Ft. Wayne, IN |
Don
That spacer is no big deal. All you need is a bushing with an OD that will slip through the idler adjusting bracket that is slightly longer than the thickness of the bracket. It needs a 3/8" ID for the bolt that goes through the pulley.
Thank you for your reply. Where did you find that breakdown?
Thank you, Mr. Sam Mac. I am pondering the idea of, eliminating the tension spring and going with adding the adjusting rod in place of the spring. Any thoughs on this idea?
Don
That's how I have my tiller setup. No spring.
