Old 07-11-2014, 04:28 PM
bschmittling bschmittling is offline
Default K301 Timing
I have a 124 with a Bosh coil and point saver. The points slipped and stayed open all the time so I had to re-time it. The previous owner put a nice white timing mark on the flywheel so I used that and gapped the points at 0.02. It runs and idles really smooth now but hits really hard at least once every time I try and start it. It hits so hard the starter will stop rotating. Is the timing too advanced and do I need to gap it at 0.018 to correct it? Thanks
Old 07-11-2014, 04:48 PM
Berwil's Avatar
Berwil Berwil is offline
Time it this way, don't worry about the gap.
http://www.onlycubcadets.net/forum/s...ead.php?t=4405
Bill
Old 07-11-2014, 04:49 PM
Bill
My mallware blocks the link.
Old 07-11-2014, 04:58 PM
Put it in the list of accepted sites. Sorry if that sounds blunt, but it's much easier for you to read through Matt's link than to write a whole new one explaining it.
Old 07-11-2014, 05:03 PM
I will try again tonight on a different computer. Thanks
Old 09-21-2014, 02:19 PM
I got it ironed out. Turns out the original owner didn't put the timing mark on the right spot (I'm assuming since I set the gap at .016 and now it runs great.) I also tightened the point adjusting screw as tight as I could get it and put a drop of locktight on it. No more problems with points slipping out of adjutment.
Tried to crank it this weekend and it wouldn't start again. Checked the gas. Saw some in the bottom of the tank and thought it was the points again. Turns out it didn't have enough gas in the tank to flow into the line.
Old 09-21-2014, 10:56 PM
rickx rickx is offline
Hey B,
I believe your ignition timing is still not correct. If the timing mark that is highlighted by the previous owner is the "S" mark (as it should be), the point gap should be "just barely" opening at that crankshaft position - NOT .016" open! Please refer to the PDF you noted.
Old 07-12-2014, 08:41 AM
dbuck dbuck is offline
Smile
Time that engine according to the instructions that came with David Kirks point saver. I have also found that if remove the original adjusting screw from the points and replace with an allen head screw the points will stay where you want them.
Old 07-17-2014, 08:04 AM
OldCubby OldCubby is offline
that is an excellent PDF write up!!! Thanks Dbuck for the tip!
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 07-18-2014, 05:50 AM
Smile
Your are Welcome.
