Old 07-19-2014, 09:46 PM
CubDieselFan's Avatar
Default New pick-up today
Picked up a 1810 with a bad engine today. Got several good parts. Nice 50" deck with new center double pulley, new muffler, 4 rear tires, 1 new front tire, new blades on deck. Check out the PO mods. I am not sure what the smoke stack in the air intake is used for. Maybe to pour gas in if it will not start???
Old 07-19-2014, 09:53 PM
Nice find on the 1810.
Old 07-21-2014, 12:26 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Are you going to re-use the air cleaner smokestack on the new engine when you re-power it?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 07-21-2014, 12:35 PM
jimbob200521's Avatar
Nice find! I had a 682 a while back with the same exact stinking fuel pump on it. I do believe I still have it sitting on a shelf somewhere as that thing got replaced as soon as I could!
Edit: On the 5th pic, what is that hose going into/coming from the top of the gas tank?!
-Ryan
Old 07-21-2014, 12:44 PM
Shaner Shaner is offline
looks like that "stack" is a homemade ether injection port. so you don't have to take the air cleaner off every time. must be a hard starter magnum.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 07-21-2014, 10:36 PM
Nice find!
I looked the pump up and it is 2-3 psi or so, but 42 gallons an hour. I think it is the over flow from what does not go into the carb.
Old 07-21-2014, 10:40 PM
I am not going to repower, just a parts machine. I have a 1811, another 1810 and a 1872 so it have some good stuff. I figured someone on here would want the smoke stack. May even have to auction it off.
What is bad about this mower is, only 900 hours and it is fithy in the hood. It was dirty even under the filter. I know he mowed with it last week or so, because as I was loading the 1810 a mower dealer was unloading a new zero turn.
Old 07-21-2014, 11:16 PM
FrankF3's Avatar
I bet there was a lot of dirt being sucked in by the looks of the aircleaner.
Old 07-23-2014, 11:07 PM
Yes there is grass under the filter. The engine he said still will turn over, I have not had a chance to see what is wrong. My first guess is governor gear, because there is no window in the block.
