Hello from Pa. Have a bit of a problem with my 129, fires right up idles and runs great for about 20 to a half hour with the PTO engaged cuts great then all of a sudden it starts acting like its running out of gas, and wants to die out I can choke it and it stays running but not for long. I drained the fuel tank put new gas in and put a new fuel filter on and no change runs great then 20 minutes later it stalls out. Any help would surly be appreciated Thanks Big John from Pennsylvania
Just hoping to find some advice all the folks on here seem quite knowledgible and I was hoping some advice was out there for my 129 problem if I did not word it correctly or submitted it wrong I apologize just hoping to rectify a problem
Sounds like something is getting hot then dies. I assume, once it cools down, you can repeat the procedure.
Just because it's easy, check the coil to see if there is power on the pos and neg sides, the next time it stops running (make sure the key is on and remember to turn the engine so the points are open or there will be no power on the neg side).
Thanks I will check the coil and yes when it cools down it will run again like a champ for twenty to 30 minutes then sputters and shut down , thanks for the help
Some of the heat related issues are:
* The ignition coil gets hot, the windings expand, then the coil dies. * The exhaust valve gets hot, the stem expands and binds in the valve guide. Once the tractor dies, check the primary Ignition Coil resistance with a meter to see if it falls within specifications. Check to see if you have compression when this situation occurs. Usually it falls into one of these categories but could be other circumstances.
