I'm going to put my loader on either the 1872 or 2082. I wanted to hear your opinions on front tires for a loader specific tractor. I read recently that the V61 clog up and slide if used with any mud. I was going to put ags all around, but I really wanted the carlisle tru powers, and they don't make the 18X8.50 in that size. I know there is someone on here with a 982 with a loader with ags all around, and I wonder if he has matching tires. What do you guys think?
Brent |
I can't really comment on the Ag brand to use on the front, but I can comment on Ag vs ribbed for fronts. In my experience, you are correct; the ribbed tires up front can clog fairly easily in sticky, thick mud. But for otherwise every day use (unless you play in sticky thick mud a lot), they will be just fine. As far as ag's go, from a cosmetic standpoint, they just look cool. From a function stand point, they obviously aren't going to help you not get stuck (i.e., Cub's aren't 4wd
), but they should help steering. They won't clog in mud as easily, but they will help make steering easier than turfs while keeping good traction. Hope this helps at least a little!
-Ryan
I really doubt you will be using the loader in the mud. I'd go with the V61's because they are available in 6ply. You really need the 6 ply with a loader. The you won't be disappointed. Don't go with lugs. All I see in that size range is 2ply. And all the turfs are 4 ply. As I see it, only one choice.
Pop up camper tires work good. Load rated for quite a bit too. That's what I use on my 108 and loader. Lifted a 650lb round bale and the tires did just fine
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169. Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3. |
