Old 03-14-2010, 10:55 AM
gazoriginal gazoriginal is offline
Smile cub original rear end
i have 2 questions- 1: are the rear end supposed to lock up on the cub original- only my right side spins. 2: on the left side axle tube on the rear, it is starting to leak rear end fluid out of what looks like a weep hole on the bottom. didnt know how to fix it, or if anybody has had the same problem with theirs.
Old 03-14-2010, 11:07 AM
JayBrd's Avatar
JayBrd JayBrd is offline
No, they are not a locked rear end.
As far as the leak goes, it sounds like the seal is out.. You might also want to check your axle bushing to see if they are not slopped out enough to cause the axle to "pry" on the seal to cause it to leak.
Jay N.
Eau Claire, WI
RED 82 Series...
Old 03-14-2010, 08:19 PM
Smile
where do i get seals and gaskets for the cub. thanx
Old 03-14-2010, 08:26 PM
JayBrd's Avatar
The parts resources section that list the OCC sponsors
IHCCW, ccspecialties should have it I believe.. I know one of them have the axle bushings...
Jay N.
Eau Claire, WI
RED 82 Series...
Old 03-17-2010, 06:29 PM
what is the correct fluid to put back in the rear of my cu, when i drained it, the fluid was bright red, just like trans. fluid. will that work or is that part of the problem it was leaking? thanks
Old 03-17-2010, 07:20 PM
JayBrd's Avatar
It should be Hy-Trans 7.5 pints seems right, I'll check and varify......
Jay N.
Eau Claire, WI
RED 82 Series...
Tags
axle, leaking, original, rear
