Ive got a new problem that has me stumped.
I fueled up my 128 to mow the back yard and I restarted it. The starter/generator stayed as a starter and the battery wire to the V/R started smoking. I disconnected it before it did any damage. I replaced the V/R and now when ever I put the battery wire on the post, my starter turns over even if the key is in the off position. I suspect a direct short inside the S/G. Any suggestions before I start disassembling S/G |
Check the starter solenoid.
I had that same problem on my 128. It reportedly had set for about 4-5 years UNDER a deck!!! Things were kinda stuck and I had a lot of cleaning to do. When I finally got around to re-installing the engine, every time I touched the positive cable to the battery, the engine turned over.
After thoroughty tracing all the wiring to it's supposed/stated ends, I tapped on the voltage regulator and the sparks didn't fly anymore!!! ![]() After setting for so long, the points(which set?) inside the regulator had apparently stuck/corroded together. I didn't use a BFH and lots of muscle, I gently tapped the unit with a small ballpein hammer and that did the job. Give it a try. It may be the problem. FFGino. Happy Cubbing!! |
Sounds like you have the wrong voltage regulator on it.
I don't have all of the information here with me but I believe if you remove the blue wire from the v/r it will stop doing that.
The starter solenoid is NOT the "electrical bridge" between the s/g and battery.
Go see OCC member Old Iron's write up on this matter. |
When he said:
No one here was saying that the solenoid is the "bridge". However, it is..... when you are starting the machine. Just not when it is charging the machine. To the OP: Perhaps a little clarity is in order as to which wire you are referring to as the "problematic" one. |
