Old 09-01-2014, 12:36 PM
V30crewcab V30crewcab is offline
Default Does your Haban 60" cut good?
I have a 1782 with the 60" haban on it. it cuts "ok", but even with fresh sharpened blades, and full throttle, you have to go pretty slow to get it to not miss grass. I'm talking like 1 or 2 setting, and I have to slow down more in turns. Just doesn't seem right to me. this thing oughta eat grass up with the diesel on it and running full throttle. anyone else have this issue? I'd love to speed it up but don't think I can. its the early deck. with the smaller pulley, so can't swap to a smaller one as I don't think one is available smaller.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 09-01-2014, 04:03 PM
Have you checked the engine RPM?
My Haban never cut as good as my Gravely, but, the Gravely is taller, and FASTER!!
BUT, the Haban should cut better than the deck such as one on a 1450.
Old 09-01-2014, 11:41 PM
Leadslingingdaddy's Avatar
Mine works like a dream. I cut 4 acres in about 2.5 hours with a good hill out back. Going up that and throwing heavy grass is the only time I need to back the speed off some
Old 09-02-2014, 07:58 AM
Something is wrong, it should have no problem. The 1782 should have the large PTO pulley on it and an early Haban would have the small deck pulley so you already have it sped up. I'm running an early Haban on my 2182 but I changed the deck pulley to the late style to slow my deck down. I can drop the engine RPMs down to about 1/2 and it still cuts good. Are your baffles in place?
Old 09-02-2014, 11:06 AM
pretty sure they are all there. the deck is in good shape. it has the blades on it with hardened edges too. the engine is running wide open. I've manually checked it.
72 scout
IH 404 tractor
Old 09-02-2014, 11:11 AM
Some of the hardened blades are "sand" blades.
Sand blades have a smaller "wing", and lift the grass less, they move less air, so as to lift less sand.
Sand blades will cut longer, but, not as good as a regular blade.
You might want to try standard blades.
