I recently obtained a 129 model. It has a manual lift. I installed the snow / dozer blade and have a couple issues. The first one is the the lift handle will raise and lower fine, but the rod inside the handle seems to spin around and does not always catch into the spaces.
I took the handle apart and noticed a place where a button or something may have been on the upper part of the handle. In the parts diagram, there is no button. My question is...what prevents the inside rod from spinning around? |
You are missing the rest of the button/ You need this #IH-401449-R1
http://www.cubcadet.com/wcpics/CubCa...rch_result.jpg |
OP: Either your upper "button" isn't screwed on tight, or the rod is bent down below in the "L" part that hooks into the "rooster comb". Did that make sense?
Do i need that float button for the use of the snow plow?
My real problem is that when i push the button in to lower the rod, the rod turns and does not lock into the rooster comb. It does not stay at a 90 degree angle. The rod inside the tube does not appear bent. Robert |
Without going out and hunting up an old lift arm to look at, IIRC the "L" shape on the bottom of the rod should not slide down far enough to get out of the "fork" in the bottom of the casting.
Therefore the fork should keep the "L" shape at a 90 degree angle as you described. If I have one here I'll try to look at it tomorrow and see for sure.
OK, I did a little research today and here is what I found.
I don't know what either of the two lift arms came off of, but they are definitely different. I checked each, with the buttons pushed all the way down the "L" shape would move lower than the fork of the casting and actually turn round and round on the one with the shorter fork. On the one with the longer fork the "L" shape would NOT protrude below the fork and therefore would not turn.
"rooster comb"
![]() Is that in a manual? Never heard that before. Good description though...
1966__122 Cub Cadet. Owner: Calvin, 6 yrs old Dad: Craig |
