Okay, I need to change the axle seals on a 3000 series tractor and the Cub part number is 921-3020A. This is the same seal that the cyclops machines with the 30mm axles take. Does anybody have a NAPA part# or other part # that I can get local? I'm sure my Cub dealer can get it but it will be next week before he would have it.
The seal is 30mm x 60mm or 61mm, I didn't pull it yet and I can't get a good measurement with my caliper. Thanks.
Does the old seal have a number on it? Or have you got the axle out where you can see it.....
Timken makes a 30mm X 62mm seal..... Part number 306207XX. But it's a really odd number.
Now, there is a 30mm X 58mm seal, that should be readily available. Timken #3907. O'Reilly's shows it in stock at the warehouse in my area. |
Thanks J. The only number that I can make out on the outside is "MTP 1193". I did a search on 30x60 & 30x61 and not much if anything came up. I guess I need to pull it and measure it.
Any luck?
No, and I can't tell if it's 60mm or 61mm without pulling it. I'm thinking 60, but I'll just order 2 from Cub and measure it when I pull it.
They're not much, it just takes too long to get them. Thanks for asking and I will let you all know what size they are.
