Old 10-15-2014, 07:56 AM
Traildust Traildust is offline
Default Clutch hanger for pulling clutch?
I have a 1200 that I have installed a MSC pulling clutch and I'm now having issues with the stock clutch hanger flexing. Its enough so that I am unable to depress the pedal all the way for fear of breaking something. I have heard of guys bracing the stock hanger to keep it from flexing but I cannot find anything showing just what they did. Anyone here come across the same problem? Does anyone make a stronger hanger for this clutch setup for a wide frame? Thanks!
Old 10-15-2014, 08:01 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
that's common when you put the heavy springs in. you'll need to reinforce it
Old 10-15-2014, 08:08 AM
I'm not seeing any good way to brace it or anything to brace it to for that matter though.
Old 10-15-2014, 08:13 AM
dvogtvpe's Avatar
pretty easy if you can weld and do a little fab work. WF and 82 series have the same problem .
Old 10-15-2014, 08:22 AM
I have no welder and zero experience with one unfortunately.
Old 10-16-2014, 07:09 AM
mickb72 mickb72 is offline
Default hanger
Hi Traildust, From the hole in the middle top of the hanger bolt a turnbuckle from there to a hole up inside one side of the dash. I've done a wf and 82 this way. A steel turnbuckle is best if you can find one. Some guys use a threaded rod from the hanger back through the dash bolted in front of the shifter. Mike
