Old 10-16-2014, 01:44 PM
BigCat77's Avatar
BigCat77 BigCat77 is offline
Default How much can a stock 1450 tow
Does anyone know what the towing weight of a stock 1450? I have a trailer full of wood weighing maybe 1250 pounds. Tailer itself weighs about 350 pounds.
1977 IH Cub Cadet 1450 w/Tiller
2006 Cub Cadet LT1045 w/Bagger
Old 10-16-2014, 01:51 PM
It will pull until it looses traction. Hook it up and see!
Now, if it's a single axle trailer that is going to have tongue weight, you better use a pickup.
Old 10-16-2014, 01:58 PM
BigCat77's Avatar
It is a single axle trailer. One of those build-it-yourself 4x8 trailers from Harbor Freight.
I put a 2 inch ball on the tractor so I can use it around the yard and fit through my gate.
Old 10-16-2014, 02:03 PM
Oliverpuller's Avatar
Oliverpuller Oliverpuller is offline
Be careful it is not what you can get moving but what can you stop...
1961 4 digit Original; 1963 100; 1964 70; 1971 86; 1974 169; GT3100; #1 Cart
Old 10-16-2014, 02:34 PM
jimbob200521's Avatar
Just for sh!ts and giggles, I've towed 2 Silverado 1500 pickups tied together bumper to bumper with my 2284 before That being said, John's right: it'll pull till it loses traction, but if you're going to have a lot of tongue weight, it's best to either something bigger or find a way to pull it that's not using the hitch bolted to the trans.
-Ryan
Old 10-16-2014, 02:41 PM
BigCat77's Avatar
How much tongue weight would be too much? I haven't tried to lift the tongue, I used to jack to get it off my truck.
Old 10-16-2014, 03:02 PM
I wouldn't set more than maybe a few hundred pounds on it. It would be different if it was like a cyclops with the rear plate and drawbar. Who cares if you tear that up. But, you pull the threads out of the rear end...... that sucks. If you can't pick the tongue up, I wouldn't set it on the drawbar.
Old 10-16-2014, 03:08 PM
BigCat77's Avatar
This is where I fit my 2 inch ball.
Old 10-20-2014, 02:14 PM
Stratmoore Farms Stratmoore Farms is offline
Are your rear tires loaded? Do you have wheel weights? Turf tires or ags? Grass field, gravel driveway, paved driveway? Flat, smooth, rough, hills? All of these will make a difference in traction.
I don't think that there is a magic number as to how much it can pull. Way too many variables involved with regards to tractor options and terrain conditions.
Christ died for you, live for Him!!!
Bob
