Old 10-19-2014, 05:34 PM
thadscub's Avatar
thadscub thadscub is offline
Default Removing front PTO on Cub Cadet 122
hi guys i need to remove my front pto but can't get it too budge what is the tricks to make it come off
thanks thad
Old 10-19-2014, 05:46 PM
TIMCRUTCHER TIMCRUTCHER is offline
There are two set screws in each hole. Have you taken all of them out?
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 10-19-2014, 05:49 PM
tonka.scout800a tonka.scout800a is offline
Mine had 3 short and 3 long, 1/8 allen head set screws holding it on. Are all yours removed?
Old 10-19-2014, 06:18 PM
If the arm is still on, pull it back and rotate the pto until the U shaped cutouts line up. If it's off or disconnected, light taps with a hammer on the button will allow you to rotate it until they line up.
Make sure the holes and the hex are as clean as you can get them. Use a high quality 1/8" hex wrench to loosen the set screws. There should be TWO in each hole for a total of six.
After they are all removed, then you should be able to get it off.
