Old 11-05-2014, 12:09 PM
Richs72 Richs72 is offline
Default QA-36 90 degree gear box seals
I need a set of seals for the 90 degree gearbox on this blower. The Cub Cadet web site says they are no longer available. Is there a replacement part number?
Old 11-05-2014, 12:12 PM
SKF 7628. There are others. They aren't a hard seal to find. You can match them up easy.
Old 11-05-2014, 04:19 PM
kostendorf's Avatar
They look a lot cheaper made now.
Old 11-05-2014, 05:17 PM
They still make seals like the original ones...... they are just $$$.
Old 11-13-2014, 11:02 PM
SS5150's Avatar
SS5150 SS5150 is offline
Where can I cross this SKF seal? Napa's the only parts store I really use but that number doesn't show up online.
What about the gearbox gasket itself? Is that available aftermarket?
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 12-03-2014, 02:46 PM
Okay, I have two new seals but in looking at the gearbox closely I don't see any seals, just the bearings. I found a diagram of the gearbox and there is nothing labeled as a seal, just the inner and outer bearings.
