I have a Brinly BB-360 scraper that I piked up in January with a 1450 package deal. I put it behind my 1000 for the first time. It doesn't get off the ground very far with the IH lift pin. Take a look:
![]() I have access to some 1" bar stock and a machine shop. If I made a lift pin for the scraper how long should I make it? Where should I put the hole for the scraper chain? Any help is appreciated. I m new to CC 3 point attachments. Bob |
Before you make a new pin, I would move your lower chain attachment point. It should be connected to a tab in front of the pin holding the blade on, this will give you more lift. Here is a pic I borrowed from Jeffinpa to show the tab and hole in front of the pin tube.
image.jpg Bill |
X2 on what Bill said, you need to change your lift point to get higher lift.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Thanks for the tip.
I grew up on a 108 and the 1000 in the picture. The only attachments I ever knew were a 44" mower deck and a cart. Three point lifts and rear attachments are all new territory and I really appreciate the help. I'll look at the scraper to try and figure out how best to mount the chain. Does anyone know where the lever attaches to the Brinly scraper? |
Heres a couple pics I found, don't know how much help they are
Another pic
