Old 11-16-2014, 08:09 PM
gdheck's Avatar
gdheck gdheck is offline
Default Mag 20 starter spins but doesn't engage ring gear
Just like the title says, I have a mag 20 that the starter spins, but does not kick the gear out to engage the ring gear. The starter was supposed to be serviced by the dealer where I bought the 2072. He is in the electrical repair business as well as being a mower dealer, but I personally wouldn't take anything to him. It has done this before, but I could always just quit cranking and try again and it would crank just fine. It also acts like it doesn't have the power to crank the engine very fast. It has good cables, I have used a known good battery out of my 1450 and even jumped it off of my 1782 (with a car size battery and 40A alternator conversion) without any better results. Am I in for replacing the starter or is there something else I need to be checking.
Thanks,
Geoffrey
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 11-16-2014, 08:19 PM
The bendix on that starter is just a screw. In other words, when the starter kicks in it literally "screws" the gear up to the flywheel. Most of the time some lube on it helps. WD-40 to free it up, oil or light grease to make it stay that way. It's better to do this to a removes starter. Bad news is, they're a PITA to remove. If it's not cranking very good, it may be on the way out, which would also make it not jump out well. If you've hooked it to a car battery without better results, you either have a bad connection or a worn starter. FWIW, I've heard about a million people say they have good connections. Then they buy a starter and it doesn't fix it...... and find out they had a bad connection. I'd be 100% sure it's not a bad connection before purchasing a starter.
Old 11-16-2014, 09:24 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
My father's 1862 had a similar problem. He said the battery and connections were good as well. When I looked at it, I found the battery was 9 sheets to the wind, and the negative terminal was all corroded with just a few strands left to make the connection. The starter was not getting enough power really spin up with a snap to push the bendix out there to engage the ring gear. A new battery and cable ends, had it starting with no problem.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 11-17-2014, 01:33 AM
See...... perfect example! Thanks Frank!
Old 11-17-2014, 02:14 AM
gdheck's Avatar
Ok, I'll double check the cables tomorrow and check the voltage getting to the starter.
I did see on another site that the poster had to extend the bendix all the way and spray cleaner on the drive to degrease it. I hadn't thought of it, but the dealer said he lubed the starter. It may just be that it needs cleaned. I really doubt it, but it's worth a try.
Old 11-17-2014, 08:08 AM
mickb72 mickb72 is offline
You should also take the starter apart and clean it. Check arm,brushs,comm, there's a writeup from Matt G on this somewhere. Mike
