Old 02-09-2015, 01:23 PM
gt383mag's Avatar
gt383mag gt383mag is offline
Default Cyclops front bumper
while surfing e pay i came across a front bumper for a cyclops it was at like 150 bucks. wow they are cool but 150 bucks? does anyone have one they could take a few pics and measurements off of for me i have a tube bender and wanna give one a try. would have to find the end caps but should be able to find something. as per the pics on e pay it looks like it mounts to the front of the tractor so you can still have the mule drive on is this correct. i have dies to bend 1 5/8 and 1 1/8 inch tube not sure if thats the same size but that wouldnt matter much to me if its only gonna cost me 50 bucks to make
Old 02-09-2015, 03:07 PM
BassBlaster BassBlaster is offline
I saw it as well and thought the same thing. I can make that myself for a whole lot less. I don't own a bender but the muffler shop up the street has bent steel pipe for me before and they never charge me more than about 10 bucks. Ill be curious to see dimensions too as I definitely plan to weld something up soon.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 02-09-2015, 03:52 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
The big tube is 1.5", the small one is .75". I measured the front and back side length. Around the front it was 32" and 28" around the back. So the tube should probably be 30" long. Heres a few pics.
I have one more but it is not showing up right now.
edit: found it
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-09-2015, 04:01 PM
gt383mag's Avatar
shrew how does it attach to the tractor it bolts on i assume? when you get some free time post a pic of what that area looks like. looks to me as if it bolts onto the two front holes in the frame and the top of the bracket looks to bend and go out horizontal to the ground? does the bracket cover the front of frame at all looks as tho it might be really close to hydro outlets? tube size isnt too far off 1 5/8 and 1 1/8 would look fine i think. oh and thanks
Old 02-09-2015, 04:07 PM
Shrewcub's Avatar
Yep just bolts on. Does this pic help?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 02-09-2015, 04:12 PM
gt383mag's Avatar
yeah that helps i think i can figger it out give me a few days ill try to come up with something
Old 02-23-2015, 01:57 PM
o---o o---o is offline
So does anybody else like the gt383mag bumper better that the factory one? It looks beefier and smoother to me. Good job on the bumper gt383mag
Old 02-23-2015, 02:03 PM
gt383mag's Avatar
ok wife got home and it will fit into a flat rate box without the top bar welded on if people have a welder it would save on shipping... heck you might like it without top bar....as for it being beefier the tube is i believe .118 wall mild steel? cant remember but its the stuff that NHRA mandates as minimum for mild steel for roll bar didnt think it needs to be that heavy but its what i had
Old 02-23-2015, 02:08 PM
Im okay with welding the top bar myself.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 02-23-2015, 02:45 PM
jimbob200521's Avatar
I don't have the option for welding at the moment
-Ryan
