I just picked up a 129 yesterday, and would like to set the tractor up for a plow. It does not have a sleeve hitch, and I was wondering if any wide frame sleeve hitch would work? Or does it have to come from a 129, 149, 169 etc?
Thanks. Jeff |
I believe that a sleeve hitch from any cub narrow, wide frame, through the quiet line series will work....But you must have the 3 point for your tractor as well to work with the hitch....hope this helps....Randy
Sorry, that is what I meant to say was the 3 point. Will a 3 point from a 82 series work on the 129?
Thanks. Jeff |
Sorry cant answer that one...Ive never had a 82 series so never researched it.All I have are wide and narrow frames and the the three points are different for them depending on model #.Some of the other guys will chime in and let ya know..
The cast piece and lower bracket will, but the lift bar is completely different. I'd find the correct one, which should be much easier to find than 82 series ones are, anyway.
Here are the differences with the Lift Lever (Upper Casting). The 129 would have this on the rear end of the frame. Pay attention to the welded collars on the frame.
![]() ![]() Starting in the mid Q/L series, this collar disappeared and just a hole was in the same spot. The original lift system used a "shaft" that went through the collars and the Lift Lever. The Second Generation, did away with the shaft and went to the Stud Bolt design (aka: Frankenstein bolts). See image below. ![]() The Lift Lever remained the same, but it depended what your frame setup was that determined whether you need a "shaft" or the "stud bolts" ![]() The shaft, I believe is NLA from Cub Cadet but it is simply 1/2" in Diameter and the length would be just enough tp span the frame width.
