Hello everyone. I have a IH made Cub Cadet 782 that has a seal leaking on the trunnion shaft of the hydro transmission. The seal that is leaking is on the opposite side of the trunnion. I've never replaced one of these seals before and was wondering best way to go about getting seal out. I probably will have to pull the tranny to be able to do the work. Hoping all you have to do is remove the snap ring and washer and somehow pry and pull on the seal and get it out that way. Any ideas would sure be appreciated.
Cub Cadet's I have are (1) IH 782 for pulling Trailer, (1) CCC 1711 GT with 44" Mower (1) CCC 2284 SGT with 60" Mower and (1) CCC 1864 SGT with 50" Mower. Farm tractors I have are 1956 Ford 641 and 2005 John Deere 5320 with Loader. |
put a small hole in the seal and screw a wood srew into it and you should be able to pull it out with some vise grips.
Thanks Tim. I assume I will have to pull the transmission to be able to do the work?
ive always done it with the trans out so im not sure it can be done in the tractor.
Tim, I was thinking of drilling a hole in the frame to be able to do what you suggest. I have a 1-1/16" drill to put the hole in frame.
![]() Quote:
I just did a set of hydro seals this weekend. Out of the tractor, it is a half a beer job. If you have to pull the rear, from scratch, it is a three beer job
You decide which is preferred... ![]() ![]() |
